shift assist module 1989 305
pbrad118
I have a 1989 bayliner with a 305 engine that i rebuilted. i not going to use a points distributor, but going to use a non-points distributor. will i have to use a diffen shift assist module. or will the sameone be able to be used.
Re: shift assist module
Are you actually changing the dist or just converting the points over to electronic?
If you go the Pertronix route they have a diode/resistor fix to help work with the existing ESA or you could replace the ESA with one from CDI/Rapair that works great without any extra fixes.
i just converting the points over to electronic. so if i understand this. i have two ways out. one is to add some fixes, or just get a new ESA. but i will not be able to just use the old one the way it is with the electronic
Sir, I have a new esa module that I bought and never mounted it, it is for a v-8, I have a 5.7 liter omc, the product is CDI electronics, shift assist module no. 123-9898p, my e-mail is [email protected]
