MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default Water Pump for 1978 - 150 Mercury Outboard
    How long should it take for water to start pumping out.
    I bought an old boat and motor and got the engine running but noticed that water did not come out. I shut it down right away, afraid I might damage the water pump, which may be already shot. It was on less then 30 seconds before I shut it down. Should I have run it longer?
    I was told that the motor was run last year.
    Of course I had the water coming into the intake with a water ears.
  2. #2
    Join Date
    Dec 2009
    Location
    Yuma, AZ, USA
    Posts
    107
    Default Re: Water Pump for 1978 - 150 Mercury Outboard
    Should star coming out of the tell tale hole within a minute on the muffs.
    [FONT=Impact]Best Regards[/FONT]
    [FONT=Impact]Steve[/FONT] ;)
  3. #3
    Thanks - looks like I'm changing the water pump.
  4. #4
    Join Date
    Mar 2010
    Location
    , kansas,
    Posts
    1
    thought i had same prob . cold water , thermostats. used hot water supply , instant pee. good luck and happy boating
Similar Threads
  1. 1978 - 150 HP Mercury Outboard - PSI Reading
    By aquaholictom in forum Mercury Mariner Outboard Forum
    Last Post: 06-30-2010, 03:16 PM
  2. 2005 Mercury Outboard 33 hp Water Pump
    By bozo1 in forum Mercury Mariner Outboard Archive
    Last Post: 05-25-2008, 01:56 PM
  3. 1978 175 mercury outboard
    By Fran Distefano in forum Mercury Mariner Outboard Archive
    Last Post: 02-17-2008, 10:44 AM
  4. How do you replace the water pump mercury 40hp 1997 outboard
    By rebecca wagers in forum Mercury Mariner Outboard Archive
    Last Post: 03-24-2007, 10:09 PM
  5. 1983 200hp Mercury outboard does not pump water into heads
    By david in forum Mercury Mariner Outboard Archive
    Last Post: 04-09-2004, 05:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
