MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 12 of 12
  1. #1
    Default 2004 150 hp Optimax speed and RPM loss. TPS?
    Hello I'm new to the board. This is my 1st post so take it easy on me.
    I bought my boat new in 2004. It is a 18' Nitro bass boat with a 150 optimax on it. Within the last year or so I've noticed about a 400 rpm and 6-7 mile per hour speed loss. I'm only able to top out at about 5100 RPM now under ideal conditions. I used to get over 5500 rpm. It's not the prop. I've recently changed plugs and when I did aside from them being carboned up it didn't look like there was anything wrong with them and they all looked the same. The motor runs smooth as can be and sounds great I just seem to have lost that real top end performance.
    Could it be that my throttle position sensor is just not letting the boat reach wide open throttle? To be honest I'm not even sure how the throttle sensor and connections work.
    Any help would be appreciated.
  2. #2
    Join Date
    Nov 2009
    Location
    Posts
    76
    Default Re: 150 Optimax speed and RPM loss. TPS?
    Did this start happening after weather got hot?I lose about 250 or 300 rpms when outside temp gets in the mid 90's.And if your like me,I put more and more tackle in mine as time goes by,Which is more weight.
  3. #3
    Quote Originally Posted by mainliner61 View Post
    No it's consistant no matter what temp.
  4. #4
    I should add that other then changing the plugs, water impeller, and water seperation filter this year I have never done any mantainance on it. Could there be something routine that I should have done or had the dealer do that's causing my loss in performance?
  5. #5
    Bump to the top!
  6. #6
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,116
    If the plugs were a little carbon fouled then you could have carbon build up in the heads, piston rings etc.
    Try de-carbing the motor - easiest way to do it on this model is add Seafoam to the gas..
  7. #7
    Quote Originally Posted by galamb View Post
    Well when I filled up before I brought the boat out last I did dump two 16oz cans of Seafoam in the 40 gallon tank so well see if that helps. The motor probably only has about an hour of run time on it with the seafoam. I've only run the Mercury quickclean through it once in the 5 years that I've owned it so maybe that's the case.
    Is the amount of Seafoam I added (just under 1oz per gallon) enough to decarb an engine and is it possible to add too much Seafoam or could I dump another can in? How long would it typically take to see results.
  8. #8
    Join Date
    May 2007
    Location
    Posts
    9,116
    You need to run most of it through before it will really make a difference.
    A portable 3 or 6 gallon plastic tank with your "concoction" is often the best way to quickly get it through the system...
  9. #9
    Should I run more the 1oz to 1 gallon??
  10. #10
    Join Date
    May 2007
    Location
    Posts
    9,116
    I never use SeaFoam so don't know what's recommended - a little heavy wouldn't hurt however...
  11. #11
    After doing some more reading it sounds like it may be possible to speed up the decarbing process by just removing the water/fule seperation filter, dumping out the gas in it, and then filling it with seafoam and running the motor at cruising speeds for about 20 minutes. Has anyone done it this way and did you have decent results?
  12. #12
    The Merc Quickleen is the best. I usually tell my customers to double up on the first dose(2 oz. to 6 gallons). Run the boat1/2-1 hour, let sit overnight(soak time), run again for about an hour, usually notce a diff in this time or one more cylcle.
    Hooking motor up to the merc diagnostic system(merc dealer) can determine if throttle is open all the way.
Similar Threads
  1. 2004 115hp Optimax
    By blair_brad in forum Mercury Mariner Outboard Forum
    Last Post: 03-31-2010, 10:52 AM
  2. Info on 2004 Mercury 225 Optimax
    By stevemedic in forum Mercury Mariner Outboard Archive
    Last Post: 02-08-2009, 07:40 PM
  3. Mercury Optimax 150 2004 overheating
    By snowbird in forum Mercury Mariner Outboard Archive
    Last Post: 01-22-2008, 01:34 AM
  4. Mercury 2004 Optimax 150 Overheating
    Last Post: 12-12-2007, 06:47 PM
  5. 2004 Mercury 250 Optimax with 375 hours
    By Jeff Porter in forum Mercury Mariner Outboard Archive
    Last Post: 10-01-2006, 01:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
