Does anyone have an understanding of the reference alarm and associated wiring for Chrysler 318 engines ? Is the alarm, or any feature of the alarm capable of disabling the engine if an overtemp or oil pressure threshold is exceeded ? I was running my 72 Egg Harbor on Friday, all was normal, guages all indicated normal range of operation, 55 lbs of oil pressure, 150 on the temperature guage. Cruising at 3200 RPM then all of the sudden the engine cuts out and dies. Could not restart the engine, even though it cranked. But I did notice that the alarm buzzer did not come on when the key was in the run position which it normally does, nor did the temp guage and oil pressure guage work while cranking. I'm thinking something overheated, but the guages did not indicate a problem. Went to the boat yesterday, turned the key, the engine started without problem. I have the old Chrysler 318 operating guide with a rather cryptic diagram indicating that there is a potential to wire a 2 port, 3 port, and 4 port alarm system, but no details as to how, or where the components may be located. I'm trying to understand if the alarm has any active features to shut the engine down to protect it in the event of some overheated condition, or loss of oil pressure. I did change the temperature sending unit earlier in the season since the original had crapped out. Had a very difficult time finding a replacement.
