Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2010
    Location
    Digby, NS Canada
    Posts
    12
    Unhappy Mercruiser Alpha one nightmare!!! 1990 5.7
    Where to start...I have a 1990 Bayliner Cierra 2651 with a 5.7 Mercruiser and Alpha one outdrive. Boat ran great when I first bought it last year until I snagged a rope at cruise speed. Shortly after I lost all drive. I cracked open the outdrive to find the upper end gears mashed. I brought the outdrive to a boat shop in Maine and had it rebuilt...$1400 later I picked up my outdrive and was very surprised to see the old ujoints still on it. Reinstalled the outdrive and that lasted about 5 trips. Was cruising one day and lost all thrust, overheated...as long as I kept the rpm's under 800 it brought me back to port. Called a local boat shop they told me it had to be the coupler. I pulled the boat out last September and about a month ago I pulled the outdrive off and pulled the motor out, changed the coupler(old one didn't look that bad), changed oil, filters, plugs, thermostat, gimball, bellows...did everything I figured I needed to do. Put the boat back out...noticed a noise in the back and a vibration...pushed the throttle ahead and (*!(*W^(@*&!^*&%^*&#@) it lost all thrust AGAIN!!! Put the boat back on the trailer and went home...after reading some posts on here I went out, put the boat in drive, went out behind and yep...A year befor I had simply spun the hub in my prop! Went and got a new prop...put it on...put the boat back in the water and voila....THRUST!!! After about 5 mins at cruising speed...my temp crept up to 200 and over.....limped back to my berth and went home. Went out today and changed the impeller in the water pump...cools alright now at cruising speed but the heat creeps up at idle...hmmmm? If I rev at around 700 to 800 it cools fine but at idle...500rpm it heats up. And by the way that vibration and noise is still there which concerns me...the coupler is new, the gimball bearing is new, the prop is new, the impeller is new, the engine alignment tool was used...any ideas on the vibration? Also when I took the lower off today I noticed my drive oil is GRAY...Seems like it's one problem after another...any ideas?
  2. #2
    Join Date
    Jun 2010
    Location
    Digby, NS Canada
    Posts
    12
    Default Re: Mercruiser Alpha one nightmare!!!
    Could the vibration be from the 2 o rings on the shaft? I took the boat out yesterday and steering to port made it worst and if I trim up, some of the noise goes away...the Gimball bearing is new( new greasless one)...
  3. #3
    Join Date
    Sep 2004
    Location
    Virginia Beach, VA, USA
    Posts
    809
    "new greaseless one"? ...never seen or heard of such a thing.
    Would like more info on it though.
  4. #4
    Join Date
    Jun 2010
    Location
    Digby, NS Canada
    Posts
    12
    I just called the boat shop and he says it's the only gimbal bearing they sell now...the old gimbal had a slot along the outer rim to allow grease to go into the bearing...this new one doesn't have the slot.
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,395
    Prop shaft may be bent. Shaft seals may have fishing line cuts and leaking.
  6. #6
    Join Date
    Jun 2010
    Location
    Digby, NS Canada
    Posts
    12
    Thanks guyjg...I'm gonna give in and concede defeat and haul it to the boat shop I guess...I've had the outdrive off at least 20 times since last year and it still don't work right! Learning experience though everytime.
  7. #7
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    892
    How about those old U-joints they didn't replace? That would cause a vibration although it would be worse turning or triming the drive.
    Too bad you can't swap a different drive. That would tell you at least if it's your drive or your motor. And narrow down your search a bit.
Similar Threads
  1. Evil sounds from outdrive-alpha 1 1990
    By john j. boes in forum Mercruiser Sterndrive Forum
    Last Post: 10-17-2010, 11:19 PM
  2. Replies: 6
    Last Post: 09-19-2010, 10:12 PM
  3. 1988 mercruiser 30 a bad nightmare
    By kingc560 in forum Mercruiser Sterndrive Archive
    Last Post: 06-25-2009, 11:43 AM
  4. New at this Need help to remove 1990 alpha I
    By jbwell10 in forum Mercruiser Sterndrive Archive
    Last Post: 06-20-2009, 10:56 PM
  5. 1990 43 alpha all just rebuilt butcoupler snapped
    By ibrakethings in forum Mercruiser Sterndrive Archive
    Last Post: 11-15-2008, 12:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
