Results 1 to 12 of 12
  1. #1
    Angry No Spark in 1987 Cobra OMC 3.o 4cyl
    I just replaced the coil and am not getting a spark at the plug wires. The coil is getting 12v at both the positive and negitive sides but only 6.5v out the coil. Any ideas?
  2. #2
    Join Date
    Jun 2009
    Location
    Ontario, Canada
    Posts
    165
    Default Re: No Spark in 1987 Cobra OMC 3.o 4cyl
    Don't want to pi$$ you off But did you put the rotor back on? Do you have spark at the points? Is the wire from the coil to the dis ok .
    I have a 1985 3.0 and just went through the same thing. On mine the wire from coil to points was grounding ouit where it enters the dist.
  3. #3
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    got a kill switch ?
  4. #4
    Join Date
    Jul 2006
    Location
    Keswick, Ontario, Canada
    Posts
    1,847
    Why did you replace the coil? Was it for this problem? Have you cleaned and checked the points to make sure they are making contact and opening and closing as the dist goes around?
  5. #5
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,188
    purple gray goes on positive side and black wire to diz goes on negative side. Check your fuses.
  6. #6
    Thank you all for your help. You have helped me fix the problem.
  7. #7
    Thank you for the help.
  8. #8
    Join Date
    Jun 2009
    Location
    Ontario, Canada
    Posts
    165
    What was it ?
  9. #9
    Join Date
    Feb 2009
    Location
    Lindisfarne, Tasmania, Australia
    Posts
    452
    Sounds like the case of "I forgot the Rotor"?
    Bruce.
  10. #10
    Join Date
    Jun 2009
    Location
    Ontario, Canada
    Posts
    165
    Now Bruce , if that what it was I said " I don't want to Pi$$ him off " - I think you could be right.
  11. #11
    Join Date
    Feb 2009
    Location
    Posts
    452
    We have all done stupid things in the past.
    And, laughing at them is good for the soul.
    Bruce.
  12. #12
    It was the points.
Similar Threads
  1. 1987 OMC Cobra 30
    By bowens in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-09-2009, 01:32 PM
  2. 1987 mercruiser 165hp 4cyl
    By bighands5 in forum Mercruiser Sterndrive Archive
    Last Post: 07-30-2009, 06:24 PM
  3. 1985 cobra outdrive 4cyl
    By mike_ruffo in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-19-2009, 12:55 PM
  4. 1987 Johnson VRO 140 is not getting any spark or minimal spark to the 3rd cylinder
    By yginesta in forum Johnson Evinrude Outboard Archive
    Last Post: 05-23-2007, 01:30 AM
  5. Merc 165 4cyl Spark Plugs
    By hammeresq in forum Mercruiser Sterndrive Archive
    Last Post: 03-14-2007, 09:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
