yannicksjh
Following a few suggestion about my electrical problem in my other post i was recommneded to look at the shift interupter switch for "sticking". Not really knowing what it was i looked into it today and found it no problem. This might sound like a stupid question but with the engine OFF, i put the shifter in gear (forward) and it didn't close that switch. Is it supposed to? Did the same thing in REVERSE and again didn't close it. I'm assuming when you put it in gear its suppose to slide down the rod it sits on and close whether putting it in forward or reverse? Since people were telling me that if its stuck closed the engine will NOT start because it thinks its in gear.
I can push it up or down by hand no problem. When putting it into gear it is suppose to push it closed? If so di i just re adjust it?
thanks
thanks
