Results 1 to 2 of 2
  1. #1
    Default Exhaust Manifold Test MErcruiser 120
    About to do acetone test on my exhaust mani and need to know if I need to remove the caruretor mounting plate boldted on the manifold (see pic) to do the test.
    Thanks for input,
    trm
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Default Re: Exhaust Manifold Test MErcruiser 120
    I think I may have discovered the leak in my water system. A corner of the riser showed a trace of rust and, as you see in the pic, it was completely broken and held in place by the bolt. I will also test the manifold for leaks with acetone meaning that I still need to know if I need to remove the intake manifold for testing the exhaust manifold (referred to above as "mouning plate"). Does the intake manifold have water passages? If so, will the acetone destroy the gasket between the intake and exhaust manifolds?
    Thanks for all inputs,
    trm
Similar Threads
  1. 30 lt mercruiser exhaust manifold water leak
    By brentjmorgan in forum Mercruiser Sterndrive Archive
    Last Post: 03-07-2009, 08:07 PM
  2. How do I pressure test exhaust manifold
    By Jay Reed in forum Mercruiser Sterndrive Archive
    Last Post: 09-09-2008, 09:07 PM
  3. #470 MERCRUISER EXHAUST MANIFOLD
    By kedwards in forum Mercruiser Sterndrive Archive
    Last Post: 08-28-2008, 11:37 PM
  4. Mercruiser Exhaust Manifold vs aftermarket
    By guyjg in forum Mercruiser Sterndrive Archive
    Last Post: 05-23-2007, 11:28 PM
  5. Mercruiser 470 exhaust manifold
    By cliff hartley in forum Mercruiser Sterndrive Archive
    Last Post: 02-16-2007, 04:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
