Results 1 to 12 of 12
  1. #1
    Join Date
    May 2010
    Location
    UP of Mi
    Posts
    10
    Default 0909347 cap exhaust inlet
    Mine is dry rotted. Found it by accident while working on transom. Located by starter and rear motor mount. It is rubber cap held on by a screw clamp. What is the purpose for it. Thanks Ken
  2. #2
    Join Date
    Jul 2006
    Location
    Keswick, Ontario, Canada
    Posts
    1,847
    Default Re: 0909347 cap exhaust inlet
    If it came off the exhaust manifold it sounds like the drain cap. On the OMC's you remove that when you want to drain the manifold (winterizing).
  3. #3
    Join Date
    May 2010
    Location
    UP of Mi
    Posts
    10
    this cap is located on bell housing and is on the up side. Not a drain. The exhaust goes into it at other side of engine.
  4. #4
    Join Date
    Apr 2010
    Posts
    3,473
    The bell housing was used for both V-6/V-8 mtrs. When used with a 4 cyl they capped the other side.
  5. #5
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    i just went thru this myself. I have a 4 cyl and the starboard cap developed a crack and exhaust gas was coming in the engine bay and suffacating the motor becuse the exhuast was being sucked down the carb, also water in small amounts was shooting in the boat.
    Then the crack let loose and in the water it shot like a cannon all over my motor.
    I went to home depot got a cap and was done with it 6 bucks american.
  6. #6
    Join Date
    May 2010
    Location
    UP of Mi
    Posts
    10
    thanks,Chief . If wife does not find one today in the Soo I will be in Marquette in the morning. If I can find one there on line it will save me 15 bucks. Thanks again. This rubber cap is almost 4" od 1" h 3 1/2" id. She has cap with her so will have stop at a few places.. Thanks again Ken
  7. #7
    Join Date
    May 2010
    Location
    UP of Mi
    Posts
    10
    she got it at a pluming place. I think she said $5:14 Thanks all especially to you Chiefalen. Saved me money too..Thank all Ken
  8. #8
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    My pleasure i should have posted to go to a plumbing store.
  9. #9
    Join Date
    May 2010
    Location
    UP of Mi
    Posts
    10
    I nearly screwed up big time; wife had be taking care of stuff before kids got here. Looked in a shopping bag and there was the new end cap. I thought I had put it on. Getting older sure as heck isn't making me smarter. I will do it now. I got the aux. mount on last night. Put a 5 hp Force on , it will have to do for the time being. Ken
  10. #10
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    5 hp more then enough, i know you think 9+ but to get back in 5 is more then enough i used to keep a 3 hp sears air cooled one onboard.
  11. #11
    Join Date
    May 2010
    Location
    UP of Mi
    Posts
    10
    yes but if it get rough and windy big one quits the 5 on the alum. cuddy on Lake Superior . I want to be able to control the boat.The wind blows it around.
  12. #12
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    They push big sailboats with 3-5 hp
Similar Threads
  1. water inlet hose
    By Blunight77 in forum Mercruiser Sterndrive Forum
    Last Post: 06-13-2010, 10:12 AM
  2. 40 HP LIGHTENING XR INLET MANIFOLD
    By griffo0246 in forum Mercury Mariner Outboard Archive
    Last Post: 11-20-2009, 03:47 AM
  3. Condensation on inlet manifold
    By ged in forum Mercruiser Sterndrive Archive
    Last Post: 06-05-2009, 11:01 PM
  4. Inlet Nozzel
    By seajay in forum Johnson Evinrude Outboard Archive
    Last Post: 11-29-2008, 08:28 AM
  5. Volvo 2000bs series inlet amp exhaust valves
    By Arwen Evenstar in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 09-23-2008, 12:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
