hi guys
i have a 1979 70hp johnson.
it gets to mid throttle then stalls immediatly
i have checked fuel line and sprayed some carby cleaner in but it hasnt seemed to fix problem
it will stall mid throttle in forward
also by hand at engine when engine is in neutral
when i lift the lever on the controls however it will go to full throttle in neutral then will go all the way in forward
But if i drop it back to neutral then reverse, go forward again the problem comes back, unless i take it to neutral and lift the starting handle up again.
anyone have any ideas?
