AQ130c/270 Bellows change
Rocky01
I'm changing upper and lower bellows on the o/d.
What other parts should I change out?
Also changing u-joints mine have a rusty dust on them. They look ok and there's
no looseness to them but water did get in through a tear in upper bellows.
Thanks for any info!!!
Exhaust bellows rarely go bad.
Water inside of the drive shaft bellows very likely damaged the PDS bearing as well.
You can access this area with the transmission only removed. No need to remove the entire drive for this work unless you have further Intermediate housing work to do.
You may want to examine the water neck fitting while in there.
Like Rick says on the exhaust! Don't even worry about it. Take that money and put it toward a hose nipple for the water intake and IF it's in good shape put the money back in your pocket.
