I have an early 90's 5 HP Force that will start and stay running for about 30 seconds and then starve out and die. Fuel line bulb is not staying firm and I know that the line and bulb are good because I use it on other outboards. The fuel pump was recently replaced. It seems it is running all the fuel out of the carb from the initial prime then running that out and starving and is hard to start even if I prime it again. Carb is clean as a whistle because I just went through it, float is parallel with body and everything. Anybody had other similar issues with this model? Any help would be appreciated. Thanks!
