Results 1 to 6 of 6
  1. #1
    Default Timing 2009 4.3L Vortec Mercruiser
    Can someone tell me how to reinstall the distributor on my new (2009) 4.3L crate engine? What's the procedure for timing it after the re-install of the dist.?
    I also need to find a diagram of the sparkplug wires to the individual sparkplugs.
    Thanks for the help!
    ANd one more thing: When I installed the new engine, I noticed that the un-used dipstick hole was plugged with a red plastic plug. My old engine has a pressed-in plug. I suppose that I should remove this and replace this with something a little more durable??
    AFter these little details are completed.... I'm finally going to be back on the water!
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    Default Re: Timing 4.3L Vortec Mercruiser
    Remove the solid plug from the old engine put it in the new one.
    Before installing the dist you really should "pre-lube" the engine before you first fire it.Everything else can be found here Merc Manuals or here if it`s a Balance Shaft V-6
    manual 18 GM V6 All
  3. #3
    Tried removing the solid plug from the old engine... didn't get very far because it has almost no lip to pry from.
    Thanks for the manual link. It is the balanced shaft engine.
  4. #4
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    You remove the pan and drive it up and out from the bottom
  5. #5
    When replacing the timing chain cover, do you have to drop the oil pan. I have a leak and need to remove and reseal. This is on a 4.3L vortec.
  6. #6
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,891
    Best thing is to start your own post so it dosent get lost.
    It is best to loosen the pan bolts and drop the pan a bit .It can be done without but you risk a leak from cutting the gasket.
Similar Threads
  1. Replies: 13
    Last Post: 11-03-2010, 04:28 PM
  2. Information on Timing 43 l Vortec
    By bhawes in forum Mercruiser Sterndrive Archive
    Last Post: 06-15-2009, 12:31 PM
  3. Timing 43 L 2 barrel 1998 Vortec
    Last Post: 05-08-2009, 06:23 PM
  4. Ignition Timing with Vortec heads
    By marada1 in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-12-2008, 04:38 PM
  5. Vortec timing
    By frank byrnes in forum Archive 2003-2009
    Last Post: 05-03-2004, 05:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
