Low hours engine, hadn't been run in a while.
Engine started on first key turn, ran and idle about 4 mins. in the driveway with hose connected to water intake. Ran fine, water comming out exhaust, etc. . Went to turn the water up a bit so I could ran at higher RPM.
Engine stopped, tried to restart, noticed impeller wheel was frozen and belt slipping over it as I tried to restart. Wheel could be turned by hand but it was shot (one rubber fin ripped). I replaced impeller but now engine wont turn over - Tested fuel pressure at the rail and getting some but doesnt seem real high. Dist cap contracts were dirty so cleaned. I get slightly more attempt to start with started fuild but not much more. Doesnt seem to be trying any harder to start with coil wire disconnected than with it connected.
So --- is freezing an engine at low idle by freezing the water impeller likely to bend something or cause the timing chain to slip a notch? What it the dist rotor direction suppose to be with engine at TDC on the timming mark (I dont see a notch on dist housing).? Thanks ? Other things to look at?
