Results 1 to 8 of 8
  1. #1
    Default chris craft 305k engine
    Chris craft 251 Catalina Express 1976 305 K , ? what rotation is the rotor moving. clockwise or counterwise ?? Trans is in right rotation..
  2. #2
    Join Date
    Feb 2010
    Location
    McHenry, Illinois, USA
    Posts
    75
    Default Re: chris craft 305k engine
    Most single engines turn clockwise (right hand) propellers. Check the prop, the engine should turn the same way. The exception being 1.91-1 reduction velvet drives.
  3. #3
    Thanks I trying to rebuilt this old boat , I brought it Aug. 1992 ;used it till 2005 ran it out of oil .. sat till this summer .installing 350 in it now.. JLT
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    75
    Another way to tell is when you get to the timing chain. If it has a chain with 2 gears it is automotive rotation. If it just has 2 large gears it is opposite rotation.
  5. #5
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,030
    Quote Originally Posted by jlt View Post
    I assume that you are referring to the ignition distributor rotor in a 305 SBC.... correct?
    Since all of these engine oil pumps rotate standard, all ignition distributors rotate standard...... I.E., Clockwise if viewing down on it.
    As for engine rotation...... Here is a Cut/Paste from a recent thread on similar question:
    Just an FYI here....... most single engine boats are equipped with a Standard LH (CCW) rotation engine.
    Std LH Rotation is Counter-Clockwise.
    These are most commonly viewed from the Flywheel End when determining rotation!
    RH, or Reverse Rotation, or CW rotation...., is also determined from viewing the flywheel end.
    Here are several sources of information regarding rotation.
    Click here to see more info on RH/LH rotation at Performance Product Technologies.
    Here is another one that is too large to post.
    http://slawecki.com/PennYan/Penn%20Yan%20Info/wiring%20and%20distributors/DISTRIBUTOR%20WIRING%20GM%20FORD.jpg
    Here is an image from Michigan Motors for a Standard LH rotation engine.
    http://www.michiganmotorz.com/images/DSCN1974-BIG.jpg
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  6. #6
    what is the valve setting for 305 marine chevy engine
  7. #7
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,030
    Quote Originally Posted by bert dorio View Post
    Rather than "Hy-Jack" this thread, you may want to start a new thread on this topic!
    You may have other questions to add to it as you go!
    Portland, Oregon
  8. #8
    Hi, I am a new member of forum. Would a newcomer be warmly welcome here? Good day you guys!!!
Similar Threads
  1. Chris Craft Engine Rotation
    By starfishkiller in forum Chris Craft Engine Forum
    Last Post: 01-28-2010, 09:20 PM
  2. Chris Craft Any info on Model B Engine
    By ehansen10 in forum Chris Craft Engine Forum
    Last Post: 08-26-2009, 11:21 AM
  3. Chris craft 1983 251 305k engine trans question
    By dicarlo in forum Chris Craft Engine Forum
    Last Post: 07-15-2008, 08:43 AM
  4. Help identify a Chris Craft engine
    By andrew in forum Chris Craft Engine Forum
    Last Post: 09-13-2006, 10:15 PM
  5. NEED HELP with engine selection for 32b Chris Craft
    By John Zinn in forum Archive 2002-2006
    Last Post: 02-22-2001, 01:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
