This topic has come up quite a bit lately.
Engine rotation (Ford, GM, Chrysler, etc.) is determined by viewing from the Flywheel End.
LH.... or CCW is considered Standard Rotation.
RH.... or CW is considered Reverse Rotation.
Port side engines are normally Standard LH rotation.... whether I/B trans or V drive.
As for the Camshaft....
I don't know if the Chrysler is similar to the SBC, but the oil pumps are always rotated in the standard direction on a SBC!
This can be done via cam rotation, or a Rev gear set @ both cam and distributor!
This would mean that the ignition distributor (via a Reverse Rotation gear set), would remain turning standard unless the camshaft has been reversed via "camshaft gear drive set"....... again, this would be for a SBC......, not sure about the Chrysler 318/360.
Can anyone clarify the Chrysler oil pump/distributor rotation for me?
It would appear that the Chrysler 318 oil pump is similar to the SBC double gear type oil pump.... and that these pump in one direction only! Yes/No?
