usmcdroach
ryanscolo thats the problem i was having i cleaned out the rust inside the manifolds where the water exits at i am going to test tomorrow or sat and i will let you know how it turns out
I too have had the same problem. Sporadic waterflow coming from the outdrive. Very frustrating. I think I have solved it, since I have now been running for a week with good consistent water flow.
I have stinted the hose which connects the transom through pipe to the articulating outdrive by running a smaller diameter hose through it from the transom through pipe. Pushing my stint past the bends and a tighter obstruction in the original, possibly collapsed hose. I then cut off the stint at the transom through pipe, sewed dental floss through it, and tailed the dental floss over the through pipe, fastening it with the transom to tstat hose, [neccesary because the inner/stint hose wants to move out of the obstruction/collapsed hose with the water flow].
You have to remove the plastic cover to get to the impeller housing. Undo the cover bolts and remove the impeller. Lightly grease the new one with petroleum jelly and install with a slight twist. I start the twist at about 90 degrees to the left off from the keyway so that when it gets in there it will seat on the drive key properly. You'll see what I mean. If necessary, you can take the boat into shallow water and do it in your bare feet. OK to tilt the drive all the way up to ease access. Been there. Best to keep a spare impeller somewhere in your on board spares kit. In operation the impeller is water lubricated, so no need for tons of grease.
