Results 1 to 9 of 9
  1. #1
    Join Date
    Jan 2010
    Location
    Dayton, OH, USA
    Posts
    192
    Default 1983 Evinrude 70hp idles great, no power
    I have a 1983 Evinrude 70hp on a pontoon. Just bought it and first time out. Motor starts and idles great. I put it in gear and no problems. I start to throttle up and it begins to accelerate but then bogs down and quits. Starts right up but I can get no power. This motor has no miss or idle problems but just won't run out. Any ideas? Carburetor? Ignition problem? Any help would be appreciated.
  2. #2
    Join Date
    May 2010
    Location
    Crossville (Lake Tansi), TN
    Posts
    7
    Default Re: 83 Evinrude 70hp idles great, no power
    I'm not as familiar with 2 strokes as with other engines, but if there is one thing I've learned from being on this site, it is that carbs and fuel lines are usually the culprit if it starts and runs smoothly. Also ethanol in the fuel has recently become a huge issue with all engines.
    Good luck
    ps: invest in an oem service manual from this site, it's worth it!
  3. #3
    Join Date
    Jan 2010
    Location
    Dayton, OH, USA
    Posts
    192
    A friend says he had the same problem with a similar motor (I think his was a Johnson) and he said the problem was a bad "Hi-Speed Coil". I can't find any reference to a hi-speed coil in my manual. Can anyone tell me what it is and if it could cause this problem?
  4. #4
    Join Date
    Jun 2010
    Location
    Cape Cod, MA
    Posts
    51
    I would check the entire fuel system first so you can rule that out.
  5. #5
    Join Date
    Jan 2010
    Location
    Dayton, OH, USA
    Posts
    192
    That was my plan anyway but I was just curious if anyone has ever heard of anything referred to as a "Hi-Speed Coil". I can find no reference to it in the manual or online and was wondering what it was or if it was another name for something.
  6. #6
    maybe a fuel filter, gas line not pumped up, or vent on tank not open....
  7. #7
    Join Date
    Jan 2010
    Location
    Dayton, OH, USA
    Posts
    192
    You will never guess what it was and I feel pretty dumb. It turned out to be the prop. The motor came off of a bass boat and had a 14x17 prop on it. After talking to the guys at Anchor Marine in Speedwell, TN they suggested a 14x11. Boy what a difference. I still have a slight problem with stalling but will work that out. Other than that, it runs great. I knew prop size had a lot to do with performance but I still thought it would run...I was wrong.
  8. #8
    Did u ever find out what a high speed coil is. Im having similar problems. Motor idles good revs in reverse with full power but forward has no power? my motor is a 1989 50 hp johnson any luck for u and help for me please ?
  9. #9
    Hi folks very new to the forum, I have a 78 Johnson 70 hp doing the same stuff, it runs great always starts but under the back pressure she won't come to full speed, I can't even manually hold the butterflies open and get her to come open, you can hear it trying at times but its really frustrating, any suggestions would be wonderful
Similar Threads
  1. 1991 90hp merc outboard idles great no power
    By WmS in forum Mercury Mariner Outboard Forum
    Last Post: 11-18-2010, 09:48 PM
  2. H99 starts great idles great stops after 5 mins hard to restart
    By sailorickm in forum Honda Outboard Forum
    Last Post: 09-26-2009, 11:10 PM
  3. Suzuki 25 2v 4 stroke idles great will not run
    By fire_capt_al in forum Suzuki Outboard Archive
    Last Post: 03-16-2009, 06:25 PM
  4. 96 JOHNSON STARTS GREAT IDLES GREAT LACKS POWER WHEN GIVING THROTTLE
    By craig madden in forum Johnson Evinrude Outboard Archive
    Last Post: 08-30-2007, 05:48 PM
  5. Yamaha 70hp idles great misses on acceleration
    By sucker_dave in forum Yamaha Outboard Archive
    Last Post: 07-26-2007, 01:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
