Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2010
    Location
    wisconsin
    Posts
    1
    Default 40hp Elgin problem
    i have a 40hp Elgin outboard the only numbers that are stamped on it is
    110 and then to the right of it says 4051 then the other number is 60421
    what does this mean? i am having probs trying to keep it running, i have spark and it fires but it is very rough idling and then if i put it in gear it bogges out. i did have it running full bore in neutral and it seamed it was running just fine but then i put it in gear and once again it bogged out, any idea on what i could do? thanks
  2. #2
    Default Re: 40hp Elgin problem
    Well, if the motor has been sitting for long and you havnt already, throw in some new spark plugs and remove the carbs and clean them out good,blow them out,use fresh fuel and I bet you will notice a difference.
  3. #3
    Join Date
    Jan 2007
    Location
    Edgerton, Minnesota,
    Posts
    327
    Found reference to motors made by McCulloch in 59. Model #S110A sold as Sears model 574-60421 which was Elgin branded at that time. Electric start. Someone over at http://www.aomci.org/ may have parts/service manual or advice on resetting the carb.
Similar Threads
  1. Mercury 40hp problem
    By simonj in forum Mercury Mariner Outboard Forum
    Last Post: 06-15-2010, 11:26 AM
  2. 40hp fuel problem
    By island4780 in forum Mercury Mariner Outboard Forum
    Last Post: 05-26-2010, 04:22 PM
  3. 89 evinrude 40hp running problem
    By eddief in forum Johnson Evinrude Outboard Archive
    Last Post: 05-03-2009, 01:23 AM
  4. 1994 40hp problem
    By jcshook in forum Mercury Mariner Outboard Archive
    Last Post: 11-09-2008, 09:49 AM
  5. Yamaha 40hp ignition problem
    By jez33 in forum Yamaha Outboard Archive
    Last Post: 06-23-2007, 07:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
