sandkicker
Outstanding Contributor
Ok... it starts and runs ok until the enrichment circuit times out. Then there is a very brief period when the engine runs a bit rough, then it smooths out. So far, so good. However, if I open the throttle slightly in gear or out, the engine stalls. If I open the throttle abruptly, enough to get fuel from the accelerator pump to squirt, all is ok.
The only problem is that while in gear, you can't get the engine to run between idle and about 1100 rpm without pumping the throttle continuously.
I took the top off the carb and all appears to be OK with the accelerator pump and the carb is clean.
BTW... cost saving tip for TKS carb owners... smear a very thin film of grease on both sides of the air horn to bowl gasket before installing it and when you take the air horn off next time, the gasket ( ~$20) will survive and be reusable.
