mike mladjovsky
I have a AQ225D with 280 Drive that I have owned many years. It kicks up in reverse, even with a very low idle. Began doing it infrequently about three years ago, and now it happens almost every time. Boat is only used a few times per year, parked dry, used in lake water only (Lake Powell).
The retaining collar and hooks move freely. I have adjusted the retaining pawl per the service manual; all of the springs have been replaced with no improvement. The faces of the pawls do not appear to be worn. I measured the force required to "break free" the pawls with the outdrive down and locked by using a spring gauge attached to the prop hub, and pulling horizontally aft. It takes a static pull of between 180 and 220 lbs to cause the pawls to release.
When reading both the Seloc and the Volvo Service manual, both talk about an L-shaped rod (Volvo part number 814397) that goes from the shift mechanism to press against the collar on the retaining pawl when shifted into reverse which would lock the over-center spring pawls to prevent pop-up in reverse.
My 280 is missing that rod. There is factory paint inside the hole on the shift lever which to me appears that it was NEVER installed at the factory??? No wear on the collar, either.
Any body here heard of this?
Since I have tried everything else I can think of, should I buy and install this rod?
MarineEngine.com doesn't stock this part. Where can I get it?
