MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
Thread: oil injection
    Dec 2009
    Rineyville, KY, U.S.A.
    217
    Default oil injection
    I would like to know if anyone here has the onboard oil tank, and the remote tank of a 1998 150XR6. The previous owner removed all of this, but left the oil pump and I would like to check the oiler for proper operation, so that I can put it back the way it was. Mixing gas and oil is a pain in the rear.
    May 2010
    Ottawa, Canada
    92
    Default Re: oil injection
    Are the sensors still on the motor as well as the oil pump actuator rod, you will need those as well. I would also remove the oil pump and drive gear and shine a light in the hole and make sure the crank gear is OK before you proceed or it could be a short live process. Also take a long thin screwdriver and wiggle the gear on the cranshaft and make sure that both halves of the gear are fairly tight, there is a small screw holding the two halves together.
    You can get those pretty quick on ebay, if you cannot find them let me know I likely have all the parts lying around at the shop.
    Regards,
    Dave Scott
    Aim Outboards and Machine
    613-831-1246
    Dec 2009
    217
    Thanks Dave, I'll check that today or tommorrow and let you know.
    I have a 1996 my Mariner 150'hp. People tell me I need to bypass the injection system and mix before I burn my engine up! Any thoughts would be appreciated!
    Sep 2010
    20,535
    There is a plastic gear on the crankshaft that drives the oil pump.-----Those have failed.-----Some units have a sensor that will alarm should the pump stop turning.
  6. #6
    Quote Originally Posted by racerone View Post
    Thanks for that info!
    Is there any kind of maintenance I should be doing to extend the life? Plastic and 25 years old worries me.
  7. #7
    Sep 2010
    20,535
    The motor requires a near total teardown to replace the plastic gear.----Plastic and 25 years would scare me too.
  1. OIL INJECTION
    By beacher in forum Mercury Mariner Outboard Archive
    Last Post: 03-22-2008, 06:59 PM
  2. Oil injection
    By jsalduchi in forum Mercury Mariner Outboard Archive
    Last Post: 09-05-2007, 03:59 PM
  3. Oil injection
    By jbmex1 in forum Johnson Evinrude Outboard Archive
    Last Post: 03-09-2007, 03:27 PM
  4. Ol injection
    By mandocat in forum Johnson Evinrude Outboard Archive
    Last Post: 03-06-2006, 04:24 PM
  5. Oil injection
    By ron wronowicz in forum Outboard motors archive 2000-2004
    Last Post: 07-17-2002, 09:14 PM
