Re: remote oil tank lines,what goes where?
There are only two lines when you put them into the motor one should be shorter than the other, The shortest plugs into the valve at the lower starboard crankcase, you cannot miss it it looks like a 1" nut with a 1/4" nipple on it and the other plugs into the horizontal nipple on the motor mount oil tank up near the oil tank top bracket again starboard side. Make sure you mount that line on the horizontal fitting of that "T" fitting, The lower line coming off that fitting in a vertical position should have a vent line attached to it that just runs down infront of the starter and hooks to nothing.
