captain rik
OK i was installing a new front main seal had the timing belt off as well as the heat exchanger for some dumb reason i pulled out the gear that turns the rotar.
I ddint put i back in so when i set the time the rotor button is pointing at the cylinder #4 instead of cylinder #1.
So a freind of mine told me to take out the whole distributor put it back in with the rotor pointing at the #1 cylinder.
Could some one tell if they have done this and if so is it hard to put the Distributor back in he said i would have to put it in several times to get it in the right position that it twist but i would eventually get it pointing at the #1 cylinder.
I was wondering while i had the Distributor out should i grease or oil the shaft and gear and what kind of oil or grease should i use.
From what i have read on the message board tonight to set the timing i set the gear infront of the valvle cover matching the dot on the geear to the slot on front of valve cover.
And the rotor cam has a plate with a notch and the gear has a dot.
Okay and i think im to set the crank at 0 that would be dtc but back it of bdtc about 4-6 degrees the give room to adjust the timining turning the rotor for advancement or to revers the advance.
Im all so going to replace the points with a eltronic ignition module has anyone done this as well.
any advise anyone could give me would be very appreciated as well.
thank you.
thank you.
