Port engine, no apparent overheating prior to riser/elbow changeout, probems with overheating post change.
Engine is 318, fresh water cooled, previously asked about fill levels in Sendure heat exchanger. Bought boat with no maintenance records, assumed that due to age, risers and elbows needed replacement, which was confirmed after removal.
Episode began after utilizing a infrared heat thermometer. Imbalance in temps side to side, which eventually coincided with blocked elbow disovered during replacement. Used OSCO replacements, with open gasket, which is to say, open exhaust port, and open port <top of gasket> for raw water flow.
Engine started after replacement, began to overheat, shut down, poured an additional gallon of antifreeze into heat exchanger after "burping" per Fast Jeff. All appeared fine unti tonight, restarted engine, was fine at idle, advanced throttle to 2500 RPM, engine began to overheat, approx 200 degrees, verfified with infrared on both logs. Shut down, added 2 gallons of antifreeze, which seemed excessive. No antifreez in pan under engine, nothing on the engine oil dipstick. Checked exhast, no visible sheen. Restarted engine, still overheating at around 200 degrees.
Never checked raw water impeller or thermostat prior to riser/elbow replacment, if possible can someone point me in the right direction before I dismantle the engine plumging system ?
