rolex_26_99
Hey guys I had problems with the engine overheating last time I took it out so I decided to change the impeller check the thermostat and do a complete circulation check to make sure everything was working ok but I can't seem to identify the thermostat to inspect it.
Is it located inside the part where I circled in white? or is it the two other colors?
Could someone identify all 3 parts while were at it? By witch one should I start? Is one more prone to cause problems then the other?
I have a 1997 volvo 7.4 GI/DP it has a Model # 74FGPLKD that I can't find on the volvo site BTW?????
Could someone confirm the the thermostat should open at 170 degrees?
Here is my old impeller installed that has now been replaced. Once I got it out of there it didn't look so bad.
I also had a little surprise when I opened up the gear oil dipstick. There was still pressure in the gearbox 48 hours after we used it so I'm guessing it was only humidity the milked it up and not a major seal leak. There was no water inside the foot and I have seen some pretty worse looking oil so I am hoping new oil will be all it takes.
As always guys thanks for the input
