plane_crazy
I guess I didn't want to think about it but everything tried didn't remedy the constant clunk in forward drive.
Tore the bottom end apart, the dog and forward gears are rounded. Had it apart last season and it looked perfect. Of course we used it all last season only to worsen the problem.
New gears and dog on order, seal kit also. My question is will it happen again after rebuild. Shift cable looks good. the manual shift rod and slider work good.
When we got the boat it had no forward. The previous owner had the cable out of adjustment we got it to work by adjusting the converter box, but not until we removed the lower end and reset the shifter rack and roller did it shift properly.
I guess the damage was already done, and only got worse.
The boat and motor are mint, the shift mechanism just doesn't look like it has a lot of holding power, The dog slides so easily.
