Re: '99 Suzuki DT 115 dies at idle
It sure does. It is going right along the things I have thought of that might be causing it.
My first thought was an air leak in the fuel lines somewhere but like I said, I have now changed all of those out and still have the issue. The guy who owned the boat before me told me it happened from time to time with him as well. He thought it was a check valve on the fuel tank's pickup. Well, I took it apart and it isn't a check valve, just a 90 degree fitting with the pickup tube coming out the bottom and a hose barb that screws into it for the hose to clamp onto. Plus, there is enough fuel in the line, filter, etc that if it was an air leak at the fuel tank it ought not die immediatly after pulling it into neutral.
Second thing I thought was maybe it is choking off the air. From what I can see nothing has worked loose. That doesn't mean it isn't out of adjustment. I just don't know what would be right without a manual.
Third I thought maybe a sensor of some sort but I am new to this motor and don't know what all sensors it has or which ones can cause this.
I gotta get one of those manuals.
Other than this one little issue it is a great running motor. Very good low end and runs strong. It is just bugging me.
