Intermediate Mariner
Morning Gents,
Working on a 1962 Evinrude M#35530 Lark 40hp.
Have a bad cylinder and need to rebore it.
The original oversize cylinder for that motor (#378697) is NOT AVAILABLE ANYWHERE IN THE WORLD that I have found, not on ebay, not anywhere.
The '68 piston is a little bit more available and there are a few out there. I was able to find an oversize piston (#383069) and OS rings (#380109).
The blocks are different part numbers but look identical. I called bombardier and they actually talked to me (you know how they don't like to talk to you unless you have a '98 or newer). They said c.i.d. was different but both years are listed at 43.9 cid in the book!
The '62 piston ring side clearance is 0.005-0.0065.
The '68 is 0.0045-0.007 (greater?).
The piston skirt clearance is the same (0.003-0.0045). Also endgap is the same (0.007-0.017).
The pistons look visually identical to each other and measure the same height but are differnet part numbers. The rod is a DIFFERENT part number as well, but the wrist pin is THE SAME (some light at the end of the tunnel). The underside is the same visually. The '68 piston also has a larger flat spot on top than the '62.
Can I use this '68 piston in the '62 motor? What about side clearance?
Thanks!
Shawn T
Wichita KS
Thanks!
Shawn T
Wichita KS
