omc cobra 2.3 ford
elkin1550
hello i have a 89 sunbird boat with a 2.3 ford the problem I'm having is i lose 12 to coil sometimes and #2 on the cap is not sparking and does anyone know where i can get a electronic ignition kit to eliminate points
If you put a Pertronix in you will have to cobble up a small diode doo dad to allow for the ESA module. You'll find this detailed here
Coil gets 12v from purple wire. Look for breaks, loose fittings, especially at alternator.
putting a different dist won't solve the problem, get a test light and find the bad connection and don't ignore the grounds.
Yep the grounds most forget without a ground you have no circuit.
I am wondering if anyone can tell me how to adjust the valves on my 1990 2.3 Cobra Ford engine. It's clattering like the valves need to be adjusted.
