1988 125HP tilt and trim
douginok
I have a 1988 125 HP Force outboard with the 3-wire system. I am wanting to check the fluid level and top it off if needed, but I can't find a plug or a place to fill the resevoir. If someone could tell me where to find this I would greatly appreciate it. Thanks
3w trim was not installed by Force in 1988. Perhaps you do not have a factory system?
The 1988 factory 2w system has a pump mounted to side of transom clamp. Pump has a thumbscrew that only needs to be fingertight. Catsup bottles make putting 30w non detergent motor oil into the filler hole easy. If it is a factory system then you can top off either raised or lowered.
rritt,
Thanks for the info. Maybe I described mine incorrectly. I have 3 wires going to the tilt and trim switch but only 2 going to the actual pump. Would this be a 3 wire or a 2 wire? I have attached a couple of pics,
