In the process of lifting my transmission up and out of the engine compartment I moved the drive shaft backwards.
The drive shaft moves back and forth very easily. Is this normal. Should there be some kind resitence
Last season the Stuffing Box was leaking a stream of water into the boat
This also tells me that the drive shaft is moving easily through the stern bearing and the cutlass bearing.
All help is appreciated.
