I have a aq 131 b 290 outdrive on a 21 ft imperial. Last year I was only getting 3500 rpms at wot. Afew days ago I took the prop off and straightened out some dents, also filled in some erosion spots on the blades. When I went to start the boat it would not start, so I took off the distributer and points and cleaned them up and then put in new plugs. It started. When I put it in the water and give it the gas it wants to bog down. If I ease into the throttle it will go, but only up to 2500 rpms. When i have it in N if i ease the throttle i can get it to rev up to 3000 rpms(didn't try to rev any higher than that). when its idleing it seems to be running smooth and even when i try to go thru the water. It feels like it wants to start going than pans out at 2500 rpms. Iyhought i had the plug wires on the distributer wrong so i swicthed them around. The boat then would sound rough or wouldn't start. I'm starting to think it is my outdrive or i did something wrong with the prop. I don't know.
