20hp merc 1976 200
20merc
i have a 76 merc 200 20hp merc and its leaking gear oil, i filled if 4months ago before storing with fresh oil and its all leaked out, what do i need to do to fix this?
Re: 20hp merc
You will need to replace the prop shaft seals, good luck getting the bearing carrier out you will need an oxy set and a puller to remove it, it will be a pain of a job. Before you pull anything apart make sure its not unburnt fuel oil, if it is it will be black oil
