Cancruiser
Hey all, I have a 78 9.8 that stopped running last summer. I had it in the garage over the winter and this week I took the carb apart and cleaned it out and put in a gasket kit. It was quite dirty with a couple of blocked lines.
The plugs are good and I get a descent spark (holding the plug against block and turning it over). Priming it while it is running has little effect.
It starts easy enough but only runs for a few seconds. Every once and a while it will seem it backfire while trying to start it.
The slow speed needle is set 1 1/2 turns our from seated.
BTW: The impeller was changed out last summer and water flow is good.
Any ideas as to what I should look at next? Getting frustrated with it now....
