MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Default 2007 25 hp Mercury will not run at wide open throttle
    I have a issue with my little 25 Merc, it’s a 2007 tiller manual choke 2 cylinder single carb model. The motor runs great a low speed but when you try to run WOT it bogs down. I have had the carb cleaned at my local marc dealer, changed the fuel line, cleaned the tank, changed the plugs, and changed the water pump, all of these things helped a little (maybe it sure starts easier) but it still will not pull WOT. I have checked the compression 116 lbs on both cylinders. I’m stumped any one have any sugestions?
    Vic
  2. #2
    Join Date
    Sep 2008
    Location
    Posts
    73
    Default Re: 25 Mercury will not run at wide open throttle
    Vic,
    I had a similar problem with my 25HP Merc, although it is a 1995 w/remote steering. It turned out the fuel tank vent was clogged and whenever I tried to run WOT, the carbs were not getting enough fuel. I replaced the old tank (it was pretty shabby anyway) and it fixed the problem.
    Dave
  3. #3
    Join Date
    Dec 2009
    Location
    Rineyville, KY, U.S.A.
    Posts
    217
    also check the fuel pump.
  4. #4
    I have the exact opposite problem with my 25 Mariner. It runs fantastic at full throttle but wants to die at low speed and idle. If I hold the choke out it will idle, but even when it's warmed up when I push the choke in it won't idle. Isn'y there an idle screw I can adjust to turn the idle up a little bit? If so where is it?
  5. #5
    Join Date
    Dec 2009
    Location
    Posts
    217
    Ohnomark, sounds like your slow jet is stopped up. Clean and rebuild the carbs, and you should be good to go.
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,290
    Try backing out the idle mixture screw 1/4 turn at a time and see if that helps.
    Jeff
  7. #7
    Join Date
    Jun 2008
    Location
    W.Monroe, La, USA
    Posts
    5
    Quote Originally Posted by ohnomark View Post
    Me too, was gonna ask that question but saw this 1st. Mine may or may not idle, but, it's real low.Can I add about 100 rpms? Thanks Dickey
  8. #8
    Join Date
    Dec 2009
    Location
    Posts
    217
    just turn up the idle screw, but first, clean your carb.
  9. #9
    Had that problem with my 1985 model & it was a small crack in pickup tube in the fuel tank it finally got big enough that it would just die & I found it??? Hope this helps
    Can someone tell me what the timing is suppose to be set on??? THANKS
Similar Threads
  1. 220 Crusader wide open throttle
    By pgover in forum Crusader Marine Engine Forum
    Last Post: 07-09-2010, 11:24 PM
  2. Bogging down at wide open throttle
    By wjcap4 in forum Mercury Mariner Outboard Forum
    Last Post: 03-22-2010, 09:32 PM
  3. Wide open throttle backfire
    By castaway5670 in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-23-2008, 08:41 AM
  4. 1981 evinrude 90hp wide open not wide open
    By weasel in forum Johnson Evinrude Outboard Archive
    Last Post: 05-19-2008, 09:48 PM
  5. Wide open throttle question
    By bobb in forum Outboard motors archive 2000-2004
    Last Post: 04-03-2002, 02:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
