MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Question how do i check oil sensor 1995 200 hp
    mercury outboard black max 1995 200hp xri og216310
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,116
    Default Re: how do i check oil sensor
    If you are talking about the oil level sensor, the quick check is to unplug it and see if the "beep beep beep beep" goes away - at least that's the simple test.
    Once unhooked you can check it with an ohm meter. If it shows near no continuity (lots of resistance), between the two leads (blue/black wires) and the oil tank is full, then the sensor is shot (or more often, the float in the tank that completes the circuit is shot).
    If you have no continuity you can remove the oil cap and use a piece of wire to try and snag the float and make it "mate up" with the sensor - if you get a completed circuit at that point, the float is bad (and can only be reparied by replacing the whole tank) - if you still get no continuity with the float in contact with the sensor, then it's the sensor that is shot (and it can be replaced as a single item).....
  3. #3
    i unplug horn still going completes the circuit is shot).
  4. #4
    is oil Warning Modulebad how do i check it
Similar Threads
  1. Sensor 2003 5.0 L
    By pasco99 in forum Mercruiser Sterndrive Forum
    Last Post: 07-12-2010, 10:19 AM
  2. oil sensor
    By delacova in forum Detroit Diesel
    Last Post: 05-04-2010, 01:34 AM
  3. Map sensor
    By who_cares in forum Volvo Penta Gas Archive
    Last Post: 08-09-2009, 09:31 PM
  4. How to check tachstator for 1995 Jhonson 115hp
    By johnson243 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-23-2008, 10:00 AM
  5. 1995 force 90 stator check
    By john kostyshyn in forum Outboard motors archive 2000-2004
    Last Post: 08-09-2001, 05:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
