What size battery? 1998 50 hp
Re: What size battery?
My engines always require the exact size and capacity as whatever West Marine happens to have on sale when my old battery fails. (Running 225 Johnsons with West's $50-$70 Group 24 Marine batteries.) Never had an issue yet.
My one guide suggests a minimum of 350 CCA with 100 mins of reserve capacity.
I don't have a direct conversion into MCA, but it would be somewhere in the 500-550 MCA range.
The conversion itself is dependant on air temperature and each battery will be a little different...
Note that too big a battery is not to recommend, you will never get it fully charged and just shorten the life time of your battery.
I would recommend a max of 60/75 Ah battery for that engine, any type will do, the best are the cheapest lead acid types.
If in demand for more amp-hours due to electronics etc install 2 (2 x 45/60)with a separator switch rather than one bigger (90/110Ah).
Keep one for engine only, the other for accessories.
