Oil Pan Removal??
if the oil pan is that bad then the timing gear cover bottom must be bad should come off anyway to replace the pan.
four piece gasket kit is what you need. Watch the little holes on the gear cover each one has to be clean out with a little nail or wire for the numbs of the gasket to fit.
