ffemtriley
Toward the end of last season, I had a lot of intermittent ignition performance, meaning when I went to start once there would be spark, on another try, no spark. Swapped out a couple coils and seemed to do the trick, then it just completely went.
This time I have replaced resistor, coil pack, cables, cap, rotor, and plugs, and still no spark. This leads my suspicion to the coil wiring.
I have 3 wires coming from the coil.... Two purples and one gray. One purple comes from the resistor, that one is ground when ign is off, and +14v when ignition is on. I have another purple wire coming from the side of the distributor. It has no ground no power when ignition is on or off. The gray wire (which disappears into the wind of cables working its way back to the front of the boat) has a very slight ground.
Where are these 3 supposed to be as far as (-) and (+) on the coil?
Right now, the Gray and Purple to Disto are on (+) and the purple from the resistor is on (-). This is the way they were grouped in the rubber covers so pretty sure they have been this way. Blows my mind as to why the one with 14v when isolated would go to (-).
I find it odd none of the 3 of these is grounded. My assumption is that the gray was supposed to be a ground and is no longer, and the two purples are supposed to be together on the positive side???
Thanks,
-Matt
Thanks,
-Matt
