It is an "I" and not a L. The other letters are PMDA.
I don't see any oil leaking down the chrome ram. I have wiped the trim motor and oil reservoir a few times and notice that it appears to have oil all over it again. Could water enter the system and over flow the oil resoviar and cause it to spill over. There isn't a puddle of oil, it just seems to be on the outside of the oil reservoir.
When I dropped my boat off yesterday the mechanic asked me if the engine had ever overheated before. What would that have to do with it?
Yes, that is correct. That is your Primary Drive Shaft.Part #2 in the above diagram?
No, I did not find the seals. I looked at the fifth line down like you mentioned in the link you posted.
Is the bearing you mentioned that should be replaced #4 in the diagram?
