1968 18 hp evinrude broken drive shaft
Re: 1968 evinrude broken drive shaft
Have you removed all of the retaining bolts and disconnctd the shift linkage? If so, the top driveshaft splines are frozen within the crankshaft splines.
Best procedure is to yank the driveshaft thru the lower unit water pump, then grab the driveshaft with vice grips in some non bearing area and attempt to pound it off with a hammer.
