Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2006
    Location
    Claremore, Oklahoma, USA
    Posts
    364
    Default 1989 Johnson 15HP (J15ECEC) Carburetor
    The top plastic cover (part #334050) on my carburetor has a crack in it. I found one but it is over $70.00. Can a different carburetor that doesn't use plastic be substituted?
    I am searching for a used one but no luck to date.
    Thanks,
    Bill
  2. #2
    Join Date
    Aug 2009
    Location
    Posts
    92
    Default Re: 1989 Johnson 15HP (J15ECEC) Carburetor
    Those 74-92 15hp carbs are like gold, since they are highly sought after by 9.9 owners.
    The older all metal carbs will work, but won't be as efficient on fuel and they're pricey.
    Your best bet is to bite the bullet for $70, since a used 15hp carb will cost at least that. I have sold them for upwards of $150.
    I believe the 9.9hp's of that vintage uses the same top cover(doublecheck), so that would be an option if you've got the patience to hunt one down.
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,315
    334050 supersedes up to part #433973. Are you sure about the price?
Similar Threads
  1. 1989 Johnson J15ECEC Fuel Problem
    By ko4nrbs in forum Johnson Evinrude Outboard Forum
    Last Post: 03-07-2010, 10:07 AM
  2. 1989 Johnson J15ECEC Reverse Polarity Update
    By ko4nrbs in forum Johnson Evinrude Outboard Archive
    Last Post: 10-16-2009, 08:27 PM
  3. Johnson J15ECEC 15HP Flywheel
    Last Post: 10-16-2009, 11:34 AM
  4. 1989 Johnson 15HP Model J15ECEC
    Last Post: 10-11-2009, 09:03 PM
  5. Rebuilding 1978 Johnson 15HP Carburetor Needle valve question
    By dtmolt in forum Johnson Evinrude Outboard Archive
    Last Post: 04-29-2009, 09:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
