skiffscott
My first post here! Greetings to all!
My 79 Johnson 25R79R seems to idle fine, but will not go WOT with out chugging and sometimes will just stop running. I just replaced the carb with a rebuilt unit. The old one had a bad low speed needle and the carb's bottom half was, upon research not correct for this year/model so I just replaced the whole darn thing and it idles much better now than before. I have new plugs installed as well, cleaned out the gas tank, fresh 93 octane gas 50:1 mixture. I cleaned out the fuel filter screen (it was fine). When the motor is running, it really wants to run well and sometimes it does run and rev well then the next time you crank it, it wants to chug, cough (like it needs gas or something). Also, when I pull the new plugs out they are black and wet with gas (same when I had the old carb on her). Checked spark (good and strong), checked all elec. connectors for corrosion (all good). If any one has some good ideas, I will really appreciate it. I read over all of the 25hp threads last night when I joined up and saw none pertaining to these symptoms with my year model. I don't have the points style ignition, and the plugs on this one are the type you can not gap. Thank you for any info. Scott P.S. Compression test shows 115# in both cylinders, all testing done in tank. Thank's!
