MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 26 of 26
    Jul 2009
    Orangevale, CA, USA
    12
    Angry Mercury Carburetors Leaking
    Two of the 3 carburetors are leaking gas on my 40ELPT, 4S, outboard (2000 year) motor. The leaks are between the float bowl and body, next to the plunger. I have rebuilt these twice, and used a new gasket kit the last time. The motor has very few hours, and looks brand new, but, I can't synchronize until I stop the leaks. I checked the float level, appears OK. Does anyone have any ideas, or do I assume the carbs are warped, or somehow shot??
    Thanks for any help.
    Riocasa
    Sep 2003
    New Tripoli, PA, USA!
    17,311
    Default Re: Mercury Carburetors Leaking
    Had that same problem lately.
    It's hard to do, but you need to determine it the float bowl gasket is leaking, or if it's flooding.
    Remove the carbs (again!) and rig up the gas hose right to them, one at a time. Pump the bulb until the leak happens and study where it's coming from. If it's that damn gasket--and I had a new one leak badly on me--you might want to reuse the old one. (Fastjeff's Law: "Never throw anything away!") If you round-filed the old one, then you'll have to improvise.
    If you're sure it's flooding, try lowering the float level a 1/16 of an inch at a time until it stops. Contrary to popular opinion, the float level can be set WAY lower without effecting performance. I used to run the Holley carb on my autocross car a full 1/8 " lower than "correct" to clean up its performance on bumpy tracks. The 1/8 " lowering had NO effect on output whatsoever.
    Jeff (with 50 years of carb experience)
    Jul 2009
    Orangevale, CA, USA
    12
    Jeff, thanks much! I'm now sure the leaks are coming from in front of the gasket from a hole with a brass plug with a small gap on either side (vent?); points to a stuck float (even with a new needle). When I first sprayed carb cleaner in the plunger hole, it flowed out between these gaps, but, after more cleaning, no more leakage around the plug. What do you think of using WD40 around the float pin (the float appears in good shape)? Riocasa
    Jul 2009
    Orangevale, CA, USA
    12
    I just discovered that the top carb, float to housing gasket has an "O-ring" attached to it, that surrounds the brass plug (where the leaks are occurring). Neither of the other two has this O-ring attached, and they are leaking (including the new kit I just bought). I cannot figure out why these carbs have not been leaking before, since I used the boat last year. Nobody at Mercury Marine or the Parts stores can help me understand which is normal, and I am confused re the brass plug, and what might happen if I seal it with an O-ring (if I can find one that size!).
    Riocasa
    Jul 2009
    Orangevale, CA, USA
    12
    To complete this thread, I located the proper gasket through Boats.net. It is important to talk to them since for every motor there are dozens of Models, and you must select the right one for the kit. Unfortunately, I got the wrong kit which did not have the small O-ring attached to the plunger plug, hence, the leaks. I solved for now by inserting a small, unattached O-ring, and the leaks stopped. The kits cost $40+ (must buy entire repair kit for one gasket), so an expensive mistake. I will now get a professional carb sync, and in the future, will not leave "old gas" in the carbs after use!
    Riocasa
  6. #6
    Sep 2003
    17,311
    We all learn! If you think that carb kit is expensive, the Merc 25 kit costs over 80 bucks!
    Jeff
  7. #7
    Jan 2009
    marion , ar., usa
    61
    your still getting off cheap try taking in to a shop $$$$$
  8. #8
    Check your float it might have fuel leaking into it which will weigh the float down giving it to much pressure inside the carburetor fuel bowl
  9. #9
    Dec 2019
    Las Vegas, NV
    45
    Quote Originally Posted by fastjeff View Post
    Hello, found this old thread...I'm having the same problem! Not used to working on tiny carbs like this but can't get these 77 Merc 500 carbs to stop leaking. Never had this problem before. When you mention lower float height, you mean lower it when it's upside down or right side up?It's not a major leak but I'm stumped, have replaced floats, gaskets twice, still leaking from bottom plug or bowl. Thought I finally had it, pumped up firm last time, I waited a min pumped hard, and leak began again...
  10. #10
    Can you post a pic (200 kb) of the carb, there are 2 types.
  11. #11
    Dec 2019
    Las Vegas, NV
    45
    Quote Originally Posted by Quicksilver View Post
    Here is pic, hope it attaches
  12. #12
    What is that white gunk, silicone? I think your problem is you're missing gaskets in '33"Click image for larger version.
    If you want to set the float level follow the second page instructions.Click image for larger version.
  13. #13
    Sep 2010
    24,192
    It looks to me that the white stuff is a repair of the linkage between carburetors.
  14. #14
    Dec 2019
    Las Vegas, NV
    45
    I'm going to order kits and try it again with new gaskets... I have triple checked float levels per the manual, but am thinking of also trying a lower setting, as recommended by fellow that posted before.
    Also, don't mind that throttle coupler Lol. I snapped it removing the carbs so plastic welded it together and put adhesive on it. Want to make sure this thing works right before replacing anything
  15. #15
    Dec 2019
    Las Vegas, NV
    45
    Just ordered kits to try again, but I think I may have finally found my problem. Watched a YouTube video where they rebuild my exact carbs, I think I have the main gasket that attaches the carbs to block (flange gaskets) backwards and/or flipped, so the vent hole is not lining up with carb and making an overflow situation. I hope I found the problem!
  16. #16
    Sep 2010
    24,192
    No ---That is the hole used to drive the fuel pump.----Not a vent and not your problem !
  17. #17
    Jun 2013
    Duluth Mn
    4,868
    Does it leak when it's at rest? How hard are you pumping the primer bulb? Any carb will leak past the float valve if there is excessive pressure.
  18. #18
    Dec 2019
    Las Vegas, NV
    45
    Does not leak at rest, or when it's running from what I can see. I pump it up until it's firm and just then when bulb is firm, after I hear bowls fill up, usually begins to leak, mostly from the bottom plug. Another time it leaked from side of bowl, and one time fuel even shot out of front of carb. It's been a journey to fix these.
  19. #19
    Dec 2019
    Las Vegas, NV
    45
    I am stumped. Float levels look perfect, needles and floats are new, no gunk in the seats. Going to rebuild again with new kits with the manual at my side and triple check everything.
  20. #20
    Jun 2013
    Duluth Mn
    4,868
    Your primer bulb is providing too much pressure perhaps. When did the problem first start? Either that or your floats are soaking in fuel......too heavy......"fuel logging". You said you put new ones in?
  21. #21
    Nov 2011
    tennessee
    5,481
    You have to use OEM needles as I have see to many of the aftermarkets the spring on needle is weak
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  22. #22
    Dec 2019
    Las Vegas, NV
    45
    Motor was sitting for years so after compression check, started with carb rebuild. I think I will try a new fuel line and primer bulb. I'm using a 3/8" fuel line. One odd thing is I do hear a lot of "air sucking" when I prime the bulb, which is odd. I did rebuild fuel pump/carb with Oem Merc kits.
  23. #23
    Jun 2013
    Duluth Mn
    4,868
    You must be building too much pressure or introducing small particles of debris. That would create a seating problem for the needles. I have seen this before. It often occurs on sunny days with poor tank venting.
  24. #24
    Nov 2011
    tennessee
    5,481
    Travis......3/8 line is too big..use the 5/16 line, loose the hose clamps and use fuel ties. This wont solve the flooding but will prevent fuel/air leaks
  25. Default Re: Mercury Carburetors Leaking
    I have the exact same engine. Did you solve your leakage?
    Is your engine hard to start? Mine takes maybe 15 spins.
    Quote Originally Posted by travis0332 View Post
  26. #26
    Dec 2019
    Las Vegas, NV
    45
    Quote Originally Posted by Bob in Tennessee View Post
    Yes. The manual's recommended float height of 1/4" was too low for mine...I set them higher, probably around 5/16" to stop the flooding. Leakiest carbs ever. With that being said, you still need to be careful priming these little devils...the only thing stopping a waterfall is the doinky little weak spring attached to the inlet needle.
  1. Mercury 1991 60 HP 2 Stroke oil leaking from carburettor
    By mark5116 in forum Mercury Mariner Outboard Forum
    Last Post: 01-14-2011, 10:08 PM
  2. Mercury 25hp leaking oil HELP
    By Redfox458 in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2010, 04:15 PM
  3. 2006 mercury 15 hp leaking oil through prop exhaust
    By teeitup007 in forum Mercury Mariner Outboard Archive
    Last Post: 07-28-2009, 02:25 PM
  4. Oil leaking from water intake on Mercury
    By agood1 in forum Mercury Mariner Outboard Archive
    Last Post: 05-17-2007, 09:30 AM
  5. CARBURETORS
    By K MAC in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 03-21-2007, 01:30 PM
