Re: Breaking starter bolts....Merc 3.0 I/O
Measure the new bolts!
Just got done replacing the flywheel ring gear (lot of work to get to a $20 part) because the bolts that came with an aftermarket (API) starter were about 1/8" too long. They bottomed out in the block before tightening the starter sufficiently. The bolts bent, the starter shifted, and about 20 teeth on the flywheel were sheared off.
I've done a lot of research on this. You can get the same starter bolts from your local Chevy or GM dealer for $1.68ea rather than pay $14ea from Mercruiser. the GM part number is:12338064 or the Dorman bolt from most Auto parts stores: Dorman 678-107. (This is for the style of starter with the 2 long bolts of the same size)
Mercruiser started making a mounting bracket for the end of the stater to help relieve this problem. That part number is: 863212. The bolt for the bracket is a 5/16-18 x 3/4. The nut for the starter is a #10-24. I would suggest getting these in stainless steel.
To get the broken bolts out: If you have the style with the 2 long bolts one of the bolts is relatively easy since it's a through hole, you can get to the bottom of the bolt from the top of the engine. Center punch the bolt exactly in the center, start with a small drill bit to get a good center hole started so the bit doesn't wonder, then drill down about 1/4" or so with a #10 drill bit. Most likely the bolt will just come out while you're drilling into it. If not, then start a 1/4-20 tap into the hole and this should definitely turn the bolt out. Make sure you use lots of PB Blaster or something like that if your bolt is corroded.
The second bolt, the one closes to the port side is the tough one. I suggest using the piece of bolt you just took out from the other side or a new bolt and drill into the center of it, then cut it off about 1/2 long. Use this as a guide for a center punch and a drill on the blind bolt since you can really see it from the bottom. Then get a reversed 7/32" drill bit, McMaster #
2876A24 and a drill extractor #
57195A514 you'll most likely need a right angle drill, run the drill in reverse. Take your time and try to use a dental mirror to keep it as straight as possible.
I got lucky, since my bolts were brand new they came out very easy.
Hope this helps everyone who is having this problem.
