I guess I'm a little confused. Reassembly is the opposite of disassembly. You had to remove the bottom bolt in the shift linkage connector to remove the lower unit. Just reach in through the shift connector access cover and line up the lower shift shaft to slide into the bottom of the shift rod connector and put the bolt back in. Now, what's so difficult about that? Oh yah, theres a notch in shift rod near the head that allows the shift rod connector bolt to pass thru. Above the notch and your shift rod will slip back out of the connector. Below the notch and you'll peel the threads fron the bolt. Centered in the notch, Perfect!
