Re: 120 Force motor rebuild?
JM1092, I now suspect I have a similar problem with my 1996 Merc sportjet 120 (force powerhead). I thought it was flooding but when I took it out a second time, exhaust gases blew out of the no 1 cylinder when I removed the spark plug. I did not notice any water in the cylinder so I suspected a reed valve problem. The reed valves looked good. The first time I took it out it ran great initially for 15 minutes and when I powered back to idle it died. Couldn't get it restarted. The temperature didn't go above 150 degrees the whole time so I don't suspect a crack. I guess I'll have to check the exhaust gasket now. Any suggestions ?
