Hey guys I have some intermittent issues with my motor, the 200 HP Johnson, at times I put the boat in the water and crank and crank and it appears as if it has no spark, but if that was the case wouldn’t the RPM range would not show cranking rpms??, as rpms are read from #1 firing right??? It seams that I can take all the plugs out and crank the motor some then install the plugs back in and the motor will fire right away, like if it was flooded on gas… so I’m debating between two courses of action either spark route or been flooded road…
and the issues happens may be once every five times, but once the motor runs it will re start again and again w/o issues even after 24 hours of sitting the problem seems to come back when it sits for a while like 10 days
