mercury marine high five prop
mikey43
i have a mercury marine high five prop 23 pitch has anybody try one and how did you like it??? i'am going to put it on a baja 350 v-8 alpha outdrive 21'
Well, i have to disagree with the above. The high five is a prop designed for hole shot. Can also be tuned with different plugs in the vent holes. Most likely will give better hole-shot, mid-range, and be able to plane at a lower speed than a 3 blade performance prop. U will most likely lose top end speed.
Disclaimer: propping a boat is a "black art". Different boats/engine combos will react diffrently to props. Trial and error is the only way to find out
